Ezlo WiFi + Z-Wave Smart Water Shut-Off Built-in Smart Hub & Ball Valve Kit – 1″
(5.00)5 Reviews
In Stock
$359 $325
(-9%)
Ezlo Smart Water Shut-Off Valve With Built-In Smart Hub (Control Module Only)
In Stock
1’’ Ball Valve Compatible with Ezlo Smart Water Shut-Off Valve
In Stock
In Stock
SKU: EZL-WV1BV100-US
Brands:
Shop Ezlo Smart Water Shut-Off with Built-In Smart Hub Ball Valve WiFi Remote Water Shut-Off Kit
The Ezlo Smart Water Shut-Off with Built-In Smart Hub and Ball Valve Kit 1.00″ is an advanced solution designed to protect your home from water damage. By integrating a high-quality ball valve with a smart actuator, this system offers precise control over your home’s water supply.
  • Built-In Smart Hub: The Ezlo Smart Valve features an integrated smart hub, enabling seamless connectivity with various smart home platforms.
  • Remote Control: Utilize the WiFi remote water shut-off kit to manage your water supply from anywhere using your smartphone.
  • Durable Construction: Crafted from lead-free brass with commercial-grade seals, the valve ensures long-lasting performance.
  • Weatherproof Design: With an IP67 rating, the system is suitable for both indoor and outdoor installations.
Installing the smart shut-off valve helps prevent costly water damage by allowing immediate cessation of water flow in emergencies. The system can be paired with leak sensors to automatically shut off water when a leak is detected, providing peace of mind whether you’re at home or away.
Additional Advantages
  • Easy Integration: Compatible with various pipe sizes (¾”, 1”, and 1¼”), ensuring straightforward installation in different home setups.
  • Manual Override: In case of power outages, the valve offers local controls and a manual override feature for uninterrupted operation.
By incorporating the Ezlo Smart Valve into your home, you not only enhance water management but also contribute to a comprehensive smart home ecosystem. This WiFi remote water shut-off kit ensures that your property is safeguarded against potential water-related damages, offering both convenience and security.
Manufacturer Part #: ESWV1-US / EZLO-BV-1.00
UPC: 850010800141
Description: Gen II Automated Water Shut-off Valve – Z-Wave Hub
Weatherproofing: IP67 Rating
Z-Wave module: Z-Wave 700 Series Chip
Networking: 802.11 g/n/ac Dual Band WiFi 2.4 & 5GHz
Approvals: FCC, IC
Additional information
Size:
Size:
Size:
Customers Reviews
(5)
  1. Anthony (verified owner)
    Good service.
    1 product
  2. Leo (verified owner)
    Good quality.
    1 product
  3. Leo (verified owner)
    The product is firmly packed.
    1 product
  4. Nicholas (verified owner)
    Good quality.
    1 product
  5. Kai (verified owner)
    1 product
Back to Top
chatsimple
