Ezlo Z-Wave Smart Water Shut-Off & Ball Valve Kit – 1″
(5.00)5 Reviews
In Stock
$359.95
Product Quantity
Ezlo Smart Water Shut-Off Valve (Control Module)
In Stock
1
1’’ Ball Valve Compatible with Ezlo Smart Water Shut-Off Valve
In Stock
1
In Stock
SKU: EZL-WV2BV100-US
Brands:
Shop Ezlo Z-Wave Smart Valve Kit 1-Inch With Ball Valve Kit
Protect your home from water damage with the Ezlo Z-Wave Smart Valve Kit 1-Inch. This advanced system combines a high-quality 1-inch ball valve with smart technology, allowing you to remotely monitor and control your water supply.
  • Smart Integration: The Ezlo Smart Valve Kit seamlessly connects to your existing smart home system via Z-Wave, providing real-time alerts and remote control through the MiOS app.
  • High-Quality Ball ValveKit: Equipped with a durable 1-inch ball valve, this kit ensures reliable water flow control, reducing the risk of leaks and water damage.
  • Built-In Smart Hub: The integrated smart hub enhances connectivity, allowing for easy integration with other smart devices in your home.
  • Prevent Water Damage: Receive instant notifications of leaks or irregular water flow, enabling you to take immediate action and prevent costly repairs.
  • Remote Accessibility: Control your water supply from anywhere using your smartphone, ensuring peace of mind whether you’re at home or away.
  • Energy Efficiency: Automate your water usage to conserve resources and reduce utility bills.
Ideal for homeowners seeking to enhance their property’s safety and efficiency, the Ezlo Z-Wave Smart Valve Kit 1-Inch is perfect for:
  • Monitoring and controlling water supply lines.
  • Integrating with existing smart home systems for comprehensive automation.
  • Protecting against potential water damage in areas prone to leaks.
Additional Information
The Ezlo Smart Valve Kit is designed for easy installation and comes with detailed instructions. For optimal performance, it’s recommended to have a professional plumber handle the installation. The system is compatible with standard NPT pipe sizes and integrates seamlessly with other Z-Wave devices.
Manufacturer Part #: ESWV2-US / EZLO-BV-1.00
UPC: 850010800448
Description: Gen II Automated Water Shut-off Valve – Zwave Client
Weatherproofing: IP67 Rating
Z-Wave module: Z-Wave 800 Series Chip
Approvals: FCC
Additional information
Size:
Size:
Size:
Customers Reviews
(5)
  1. David (verified owner)
    The product is firmly packed.
    1 product
  2. Dominic (verified owner)
    Good service.
    1 product
  3. Avery (verified owner)
    Very fast delivery.
    1 product
  4. Michael (verified owner)
    Very well worth the money.
    1 product
  5. Charles (verified owner)
    1 product
Back to Top
chatsimple
