Ezlo Smart Water Shut-Off with Ball Valve Kit – 1¼ Water damage is the leading cause of insurance claims. Nearly 45% of the population has experienced water damage in their home or knows someone affected by it. With an average claim of over $11,000, it’s time to get smart about water and freezing damage. The Ezlo Smart Water Shut-Off Valve is the industry’s smartest water management solution, featuring a two-part design — ball valve and actuator, regular, automated ball valve movement to keep your shut-off clear, and powerful smart home automation through Ezlo’s MiOS platform. The Z-Wave Client version of the Ezlo Smart Water Shut-Off Valve is compatible with many Z-Wave smart home hubs on the market.
This bundle comes with a 1¼” Ball Valve. If your home has a different pipe size, please choose the correct valve size from this catalog.
Manufacturer Part #: | ESWV2-US / EZLO-BV-1.25 |
UPC: | 850010800448 |
Description: | Gen II Automated Water Shut-off Valve – Zwave Client |
Dimension (LxWxH) : | 6.25 x 7 x 3.78 in |
Power Supply: | Voltage: 110 VAC converted to 24V DC (Class 2 power converter with 20’ cord, 1.3A full load |
Weatherproofing: | IP67 Rating |
Z-Wave module: | Z-Wave 800 Series Chip |
Materials: | Lead-free brass ball Valves with commercial-grade seals. Polycarbonate enclosure, NEMA 4x (weather resistance) |
Usage: | Comes in standard NPT size (¾”, 1”, 1¼“) (Sold separately) |
Approvals: | FCC |
There are no reviews yet.
