Ezlo WiFi + Z-Wave Leak Prevention Kit – 1¼
0 Reviews
In Stock
$495.95
Ezlo Smart Water Shut-Off Valve With Built-In Smart Hub (Control Module Only)
In Stock
Ecolink Flood & Freeze Sensor with Flood Probe × 3
The perfect solution to alert you in case of flood or extremely low temperatures.
In Stock
1¼“ Ball Valve Compatible with Ezlo Smart Water Shut-Off Valve
In Stock
In Stock
SKU: EZL-LEAKPREV-KIT-125
Brands: ,
Ezlo Leak Prevention Kit – 1¼
An Affordable Defense Against Water Damage! Take control of your home’s safety with the Leak Prevention Kit, a comprehensive bundle featuring the Ezlo Smart Water Shut-Off Valve With a Built-in Hub and three Z-Wave leak sensors. Designed to seamlessly integrate with the MiOS App, this powerful kit is your first line of defense against leaks and water-related disasters, ensuring a smarter and more secure living environment. Guard your home against leaks with the three Z-Wave leak sensors included in the Leak Prevention Kit. Strategically place these sensors in areas prone to water-related issues, and let them communicate seamlessly with the Ezlo Smart Water Shut-Off Valve hub. Receiving instant notifications through the MiOS App provides you with real-time alerts, allowing you to take swift action and prevent potential damage.
This bundle comes with Ezlo Smart Water Shut-Off Valve with Built-in Smart Hub,  3x Ecolink Flood & Freeze sensor with flood probe and the 1¼” Ball Valve. If your home has a different pipe size, please choose the correct valve size from this catalog.
Manufacturer Part #: ESWV1-US / EZLS1-US / EZLO-BV-1.25
UPC: 850010801001
Description: Gen II Automated Water Shut-off Valve – Z-Wave Hub Version /  Ecolink Flood & Freeze sensor with flood probe
Power Supply: Voltage: 110 VAC converted to 24V DC (Class 2 power converter with 20-inch cord, 1.3A full load
Weatherproofing: IP67 Rating
Z-Wave module: Z-Wave 700 Series Chip
Networking: 802.11 g/n/ac Dual Band WiFi 2.4 & 5GHz
Approvals: FCC, IC
Additional information
Size:
Size:
Size:
Customers Reviews
There are no reviews yet.
Back to Top
chatsimple
