Enbrighten Zigbee 3.0 Plug-In Switch Module Dual Controlled Plug, No Energy
(5.00)5 Reviews
In Stock
$55.95
SKU: JA43094
Brands:
Shop Enbrighten Zigbee 3.0 Plug-In Switch Module Dual Controlled Plug – No Energy
Introducing the Enbrighten Zigbee 3.0 Plug-In Switch Module, the ultimate solution for smart home automation! This versatile device allows you to control your appliances with ease and convenience, all from the palm of your hand. With dual controlled plugs, you can switch on or off two devices simultaneously, making it perfect for lamps, fans, and other electronics. Plus, it’s energy-efficient, so you can save on your electric bills while enjoying the benefits of a smart home.
With Zigbee 3.0 technology, the Enbrighten Zigbee switch connects effortlessly to your favorite smart home platforms, including Amazon Alexa and Google Assistant, for seamless voice control. The compact design makes it easy to plug into any standard outlet, and the sleek, modern look complements any home décor.
Key features of the Enbrighten Zigbee 3.0 Plug-In Switch Module:
  • Manage two devices simultaneously, ideal for various household electronics.
  • Effortlessly connect with Zigbee-compatible platforms like Amazon Alexa and Google Assistant for voice control.
  • Reduce your electric bills while enjoying the conveniences of a smart home.
  • Easy to plug into any standard outlet without occupying much space.
  • Modern design that blends seamlessly with any home décor.
Upgrade your home with the Enbrighten Zigbee 3.0 Plug-In Switch Module and experience the ease and convenience of smart home automation. Order yours today!
Product Specs of Enbrighten Zigbee Switch:
Manufacturer Part # 43094
UPC 030878430944
Color White
Protocol ZigBee HA 1.2 – Certified
Signal Frequency 2.4 GHz
Wireless Range Up to 150 feet line of sight between the Wireless Controller and the closest ZigBee receiver module.
Power 120VAC, 60Hz
Max Load (Both ZigBee Outlets) Incandescent: 600W (5A)
Motor: 1/2 HP
Resistive: 1800W (15A)
Operating Temperature Range 32° to 104°F (0° to 40°C)
Environmental Conditions For indoor use only.
Approvals FCC, IC
Warranty 2 Years
Customers Reviews
(5)
  1. Robert (verified owner)
    Good service.
    1 product
  2. Henry (verified owner)
    Good quality.
    1 product
  3. Kai (verified owner)
    The product is firmly packed.
    1 product
  4. Samuel (verified owner)
    Very fast delivery.
    1 product
  5. Samuel (verified owner)
    Very fast delivery.
    1 product
• Datasheet Pdf
Back to Top
chatsimple
